I'm not sure if this is already possible, so if it is please enlighten me!
I'd like to be able to pause effects that are running in a cuelist. Eg. Q1 makes all movers do a circle effect, Q2 pauses all fixtures, Q3 continues the effect.
I realise you could just record a position into Q2 that is somewhere in the path of the effect but this will mean the fixtures will jump (or fade depending on fade time) to that position when the Q is triggered and not just stop where they are. Equally if it was a colour effect or an iris effect you wouldn't know where in the cycle the effect will be in order to record a hard value for this.
Hope this makes sense!
Andy
