I know how to set it on individual faders, what I would like to know if there's a way to tap or set the bpm globally to effect more than one fader. For example I have a gobo chase on master 2, and a color chase on master 3, anyway to change both bpm's at the same time
There really isn't any way to change the BPM of multiple masters at once. But, if you consistently run these chases together then you could try this:
Disable chase on the two individual cue lists Record a third cue list with two blank cues and add GL macros to those cues that trigger the other two lists You can then use tap sync on that third dummy list to change the rate of go's on the other two masters.
Not the best solution as I realize you might want chase the lists individually at times as well; but it's a start.
Yes these are logged... but also there are enhanced concepts logged that ustilize the rate wheel or other newer concepts instead of just rehashing the Wholehog 2 methods. These are currently on the wish list....
[quote=c_muenchow]There really isn't any way to change the BPM of multiple masters at once. But, if you consistently run these chases together then you could try this:
Thanks for the help, I'll give that a shot and see if it works out.
