programe wing issue
I have been having issues with my programe wing when pressing the numbers on the key pad. when i enter a number it some how regesters as a double or triple press. would this be a problem with the wing or with the settings in prefrences?
Cheers
Steve
  • Hi,
    In Hog III PC try
    "Setup"
    "Prefes"
    "keyboard timings"
    adjust some of these settings and see if you can get your keyboard to work correctly and as expected
    Might also be worth trying to un-install/reinstall Hog III PC just to see if this fix's any errors.
    Make sure you don't have anything sitting on or near any external keyboards or devices that might be creating this problem.
    Others will post with other solutions,
    good luck,
    C
