Pig + @ (Unpatching in view by DP) BUG
Version 2.3.1 it seems that the [pig] + [@] shortcut to unpatch does not work. Not just the shortcut but also the [Unpatch @] button.
More precisely, it does work for a fixture with user number 1 that is patched to dmx 1. However, it does not work with fixtures with other user numbers (where it is patched is irrelevant).
An example for further convincing:
Let us patch 10 VL3500 Spots.
VL3500S 1 > 10 @ 1
Now we have successfully patched 10 fixtures. Note that our user numbers are 1 thru 10.
Now we shall unpatch fixture 3.
[pig] 3 [@] 3
This did not unpatch the fixture.
Next try to unpatch fixture 1.
[pig] 1 [@] 1
Fixture 1 is unpatched.
q.e.d
-BC
  • Gotta say... love the "q.e.d." at the end.... been a while since I had to do mathematical proofs...
  • The reason it works with with [pig] 1 [@] 1 and not [pig] 3 [@] 3 in this case is because the Hog unpatches by dmx address and not by fixture number. In fact, you don't even need the fixture number.
    Hold [pig] and press @, release both buttons, and then type a dmx address or range of dmx addresses.
  • Thanks.
    Perhaps you may want to change how the manual is worded. Currently it reads:
    "Pig + @: When patching with View by DP enabled, unpatches the selected fixture."
    Thus, my confusion.
    -BC
