Road Hog & IPC
Hello all,
just wondered if it was (or if anyone had tried off the record) installing IPC software onto the Road Hog?
Cheers
  • The Hog3PC software is the same across all platforms.
    Anything else won't work.....different hardware, the drivers will not be in the XPe image not to mention the BIOS conflicts.
    I imagine very bad things for the poor RoadHog that someone tries this on!:eek: :eek:
  • [quote=neil-NSLX]Hello all,
    Cheers
    This is a curious question......Why would you want to do that? Even if it did work (which I doubt), it would be a major downgrade in functionality for the console.
  • Hello,
    I was just wondering.
    I like the Hog 3 operating system - but some of my dry hire-ies prefer the H2 operating system.
    Although to be fair, since Mark Cues have arrived in H3 - this probably will make requests for H2 software not happen.
    I obviously wouldn't try it unless someone else had found it to be ok ;)
    Cheers
  • [quote=neil-NSLX]Hello,
    Well...It looks like your fellas need to step up to the BIG LEAGUES and play on the HOG III platform. :)
  • FYI..
    We have a protection scheme that will not allow the various XPe images to be loaded on the wrong platform. This protects customers from loading the wrong image and also meets with a requirement by Microsoft related to the distribution of XPe.
    If you want to help people understand the benefits of the current Wholehog software over the older Wholehog 2, send them to this link:
    www.highend.com/support/downloads/dl/Wholehog%20Operating%20Software.pdf
