iPC Palette issue
Two questions...
1) How do you deselect a palette when running the latest version of H3? It's a bit of a pain when I generate auto palettes for a Studio Spot 575 and I accidently click the wrong palette on the color or gobo and can't deselect.
2) The other day I was on a show and started recording palettes. When I went to recall them the fixtures did nothing. If I moved one of the wheels on the console that particular parameter would come alive to the recorded position. Any reason why this was happening? A hard reset resolved the issue but a rookie programmer on the show was going nuts.
Sid
  • [quote=SidAspect]
    Either press UNDO or hold down the backspace and press either COLOUR or BEAM or physically touch any of the encoders to knockout parameters separately.
    [quote=SidAspect]2) The other day I was on a show and started recording palettes. When I went to recall them the fixtures did nothing. If I moved one of the wheels on the console that particular parameter would come alive to the recorded position. Any reason why this was happening? A hard reset resolved the issue but a rookie programmer on the show was going nuts.
    That sounds odd...never run into this myself, what version are you running? any externals plugged in to the console?
    The only things I can think this might be (other than a SW problem ;) ) is that you had something in your programmer that wasn't CLEAR-ed, you were in BLIND....or another EDITOR window open or something like that. PARK might also prevent you from doing things, but PARK does not get cleared on a restart....
    Hope this helps :)
  • Hi,
    you don't say what version of software your running but it sounds a little like an older problem like the "enter" bug.
    forums.highend.com/showthread.php?t=3793
    Try this link to see if anything is similar.
    Cj
