(1932) - Bug Report - Command Line Cue Split Times Editing
Build 1932 - Bug Report
2 x DP
1 x H3
This may have been a "day-1" bug.....
CUE 2 COLOR TIME 2 ENTER
This will set the color time in cue 2 to 2 secs... without going into the cue...
This syntax works with all normal combinations (ie... delay... specific groups of fixtures)..
.. but
CUE 2 COLOR TIME 2 THRU 10 ENTER
Doesn't set the fade times to split times......
.. for some reason, the split time syntax (x THRU y) does not work using this entry method.
D
