Can someone inform me if there is another way to update a palette w/ a 'global' or 'per type' setting? If I open the palette, I'm not able to change anything unless I add a fixture (yes, edit is enabled), but then that particular fixture is in the palette. I realize I can just merge or replace info from the programmer, but it seems like I should be able to update global and per type palettes when I bring them into an editor via "Colour 1 Open".
Using the current build on an iPC.
