Manual Correction
I think the manual for V2.3 needs a slight correction
Moving and Copying Cuelists between Masters
Moving a cuelist between masters will detach it from its original master. Copying a
cuelist between masters will leave the cuelist in its original location, and attach a copy
of the cuelist to the new location.
To move a cuelist:
1. Press the Choose key of the master that you want to move the cuelist
from.
2. Move
3. Press the Choose key of the master that you want to move the cuelist
to.
The Syntax is actually Press and Hold Move, then Hit Choose of the master you want to move. Release Move (Command Line will Read Master X Move To) then hit the destination choose.
If I do this with the Choose above the Main Playback Controls I get
Master 4294967295 Move To. I didn't know the 3 had so many playbacks!
Running 2.3.2 b1948
Best wishes,
P
