Bug? Live+palette+suck
Working in b.1932, when I use Live+palette+suck to pull fixtures using a specific pallette into the programmer it works fine using the touch screen to select the pallette, but if I enter the palette number manually (i.e. using the keypad, Live+colour 26+suck), then it acts like "suck" (not active) AND it then applies that particular palette to all of those fixtures. Is this right? I often memorize frequently used palette numbers and use the keypad instead of the touchscreens.
Dave
