hog 2 pc not working with hog 3 widget
I couldn't get the hog 2 pc to communicate with the hog 3 widget, no lights on the widget would even come on. I then tried to install hog 3 on the laptop but that wouldn't work either. It's not my machine and I couldn't access install new hardware due to admin restrictions so I couldn't install the loopback adapter. Is there anything I need to due to make hog 2 work with the widget? Any tricks to get hog 3 working without the loopback adapter?
Thanx.....
  • Any network connection will keep you from needing the loopback adaptor. So if you computer is connected to a wireless network or a hardwired network you will be able to use Hog 3. Were you using a good usb cable? Widgets are high power usb devices. Have you tried using a powered usb hub? Lots of laptops only have low power usb ports.
  • we wound up using another laptop with hog 2 on it, so the usb cable is ok...don't know if the usb on the first computer was low powered or not...I never realized that could be an issue.
  • If admin restrictions prevent you from using the loopback adapter, they may also block you from getting at the device drivers you need to run a widget. It will depend on how your sysadmin has it configured.
