hog III. submaster fader set to "manual crossfade". anytime i put the fader to 100% it goes to the next cue in the list and then when i bring it back down to 0% it advances to the next cue again. i have done this a thousand times.... crossfading strobes, gobo rotation etc... i have never seen this before. everyone here is stumped. any help would be greatly apprecitated. thank you
sounds like you want to use the fader as a IPCB fader not manual fader. Manual fader relates to manually fading between cues. IPCB fader inhibits the output from the cuelist assigned to it.
