The Full Boar and Touchscreens
I have done a search but cannot find anything about this. I have a Full Boar and I am having a little trouble with the external touch screens. I bought 2 that were recommended by Brad in another thread. However when I boot up the console, the screens offset to one external and on internal and the other two don't turn on. I am on the latest software update. I wouldn't think that this should be happening and that people have external touchscreens that the leave connected all the time. The only work around I have seen is to disconnect the DVI cables from the console, boot the console, then reconnect and re-calibrate every time. Any tips or tricks would be helpful.
Eric
Parents
  • I use the DVI with the USB because it hasn't worked without the USB connected. It is also easierto use the DVI straight through than converting from DVI to VGA.
Reply
Children
No Data
