thirst cue in cuelist overides other cues in same cuelist
Hello
I'm relatively new the hog consoles, currently im working with a hog 3 PC Setup. Thirst I have two say realy nice work! :hogsign:
But If have a litle problem, maby someone can :1zhelp: me out:
I have a allready existing show i'm modifying and ther is a cuelist with only one cue in it, with sets 2 desk channels to 100%. now when i add a second cue to the list, where 2 other channels a set to 100% and i adwance to this new cue in the cue list the two from the thirst cue stay at 100%. The Ouput window says that the source ist the 1. cue of that cuelist. the 2. cue works as it shoud and set the two other channels to 100% only when its active, but the 1. cue sets the two other channels allways to 100% only the masterfader modifys the value.
If somebody could tell me what kind of feature this an how you can switch it on and off i would be glad
Thank You
Peter
EDIT:
OK Found the problem, I did't understad the Tracking feature, now everything is clear. (Activating Cue Only solves the problem)
