I know that if you scroll the cue list, the Follow Cue disables, but mine has been disabling alot today, and it's usually when I create a new cue, and has nothing to do with scrolling the cuelist. Any thoughts?
Do you have a view with the follow cue turned off? Maybe you are recalling a view (that leaves the cuelist window open) that changes the status of this button....
Mike and I have both looked at your show file and recorded a number of cues and have tried to reproduce the issue but the follow cue option is staying on every time. :confused:
This is still coming up every once and a while. It could be part of the same issue I've had forever now...when creating a new cue, almost always, the "End" cuelist bar at the bottom of the cuelist goes away. I have to constantly refresh the list by hitting the Choose key. It could be that hitting the Choose key somehow toggles the Follow Cue off.
Hmm and it is only when creating cues? It could be related to pressing Choose. I am curious... your cuelist window... what monitor is it on and at what resolution?
