Busking with IPCB Fader
Setup:
HOG3 console
Expansion Wing
Latest build (I believe, probably not relevant)
I am pre-programming a show for busking, and setting up some faders for parameters of MAC 700 Profiles.
Among the faders...
I want one of the faders to be GOBO1 Rotate.
And another fader to be Prism Rotate.
I did this by setting only that parameter in the programmer to its desired top level, like say 150 rpm.
I programmed this to a SCENE.
Then I moved that scene to a fader, and set the list options to IPCB Fader.
The Prism rotate works fine, but the GOBO1 rotate Releases if you go to the 100% and start backing down from that.
For the GOBO1 rotate...
I temporarily implemented the "old way" of doing this by having two cues (cue1 at 0 prm, and cue2 at 150 rpm) and setting the options to Manual crossfade.
Thoughts?
btw, this is only my second time setting up for busking, I've done lots of cue-to-cue shows on the hog.
