iPC Full Sys Restore Possible from a Flash Drive?
Is it possible to use a bootable flash drive to do a full system restore on an iPC?
If so can the bootable flash drive be created on the iPC or will I need to first format the flash drive using the instructions listed in the "BootableUSBFlashDrive.pdf on a vista machine?
Joe
