I would like to be able to select the Cue-lists  that i want to merge rather than having to mege,append or replace all.
Other than creating a source show that deletes all of the un-required cue-lists and then re-opening the current show can someone tell me how to add specific cue-lists rather than all.
I have several versions of the same show which i sometimes want to add one or two cuelists from another show with exactly the same name's,pallettes,groups,views etc.
Maybe i do not have a proper grasp of the options available and the correct way to merge shows.
Any ideas or suggestions appreciated.
Regards C
