Hey guys, i have a problem with a show i have prgrammed uysing mac 700's profiles and washes. In my cuelists it runs through the changes for all conventionals but when it comes to position or palletes for the macs it snaps them at the end isntead of using the cue timing. any ideas? is there somethig i have missed?
you might have missed lot of things. Check what's the default time for position beam color. It sounds like your default time for these kinds is set to Zero. Whenever you record a new cue your color beam and position are given a 0 sec fade in time. Try to change your dafault times under preferences and you should be albe to achieve a smooth crossfade for every kind. If it doesn't work repost with more details about what your problems are and sure someone here can help you to sort it out hope this helps Marco:hogsign:
