Bug Report: Undo doesn't undo the latest after a 'double' patch.
2.5.0 Bug Report: Undo doesn't undo the latest after a 'double' patch.
Date: 02-06-1980
Software Version and build number: Hog III 2.5.0 b2063
Number of displays: 2
Connected USB Devices: 1x Exp. Wing
Networked Devices: 1x DP2000
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
Go to patch. Make 10 deskchannels. Now patch 9 and 10 at channel 5 and 6. Then patch 1 thru 8 at channel 1 on the same line. The following message appears, as 5 and 6 are already in use: 'Could not patch as there is another fixture in the way. (Desk Channel 5). Would you like to remove existing fixture?' Press 'No'. The first 4 channels will be patched from 1 to 4, the other 4 channels will stay unpatched. When you press 'Undo' it will delete the patch of deskchannels 9 and 10 and not from the latest patched 1 to 4.
List any errors reported by the software:
None
