ZERO Key issue on the Roadhog Full Boar
Hi Guys,
I'm sitting here at home and am doing some programming for a design proposal and just noticed that all the numberblock keys except the "0" (zero) submit their values on-push (you push 1, and as soon as the 1 key is pressed completely the software will take the 1 into the command line). Zero does that on release of the button which I think is VERY annoying because I usually type 610 thru instead of 601 thru and all that.
this should be a VERY quick fix in the source.
Would you please change that? and nope, I am not going to type slower because my speediness is what I get paid for ;)
(dont mean to sound rude...!)
cheers and thanks!
