I'm having some problems with the touch button on an iPC running the newest version of Hog3. We have 7 VL3000 Spots and whenever I select them and touch them, the iPC pulls out all of the gobos and color. For example, on the output screen, before I push touch, gobo 1 is listed as having "pebbles" in it, but after I push touch, it is listed as "open." The same goes for many of the other parameters (not intensity or color though). In the past, touch has just pulled what is being outputted into the programmer. Has this changed?
Before the question is asked, no High Light is not pushed.
Kevin
