Friends I stumbled into this by accident, as I use normally enough wings to avoid things like that, but this time one wing were stuck on transportation, so:
I decided to use the page option "leave in background". Most of my Movement Effects are always recorded as effect only, means no P/T Information in it.
But as soon as I leave the Page, where this Movement FX is on, the FX releases itself.
I found out, as soon as I got a Position Information together with that fx in the Cue, everything is fine, and it won't release with a Page change.
To do the official way:
Date: 07/09/08
Software Version and build number: 2.6.0 (2071)
Number of displays: one
Connected USB Devices: 2 x PB Wing, 01 x PR Wing, 01 x Super Widget
Networked Devices: none
Detailed Description to be found above.
the Workaround I did was to integrate these FX Only Movement Cues into a template Page and everything was fine.
Best
