'Select Group X' Command Macro
I have cuelists with cues where certain moving fixtures go to a certain band-position. Of course every now and then the musician is not on it’s place so I need to adjust the position manually as quick as possible. With a command macro ‘Select Group X’ this specific group of moving fixtures could automaticly be selected when playing the cue. If it needs adjustment, it’s done quick and easily, if the musician is in place just press ‘Clear’.
Anyone else has any ideas on this?
Gr.
Pim
