Sizable Palettes
Has there been any discussion to add this? I abolutely love using my tabletPC as a remote, but what drives me crazy is that on my tablet, the display can fit more than 12 palettes across. I am very particular about palette placement, and when the console doesn't match the tablet, it can be frustrating. Sizable palettes would allow me to have identical layouts on both consoles. Any chance this will be added?
  • Hey Scott,
    I am with you on visual placement of palettes.
    Right-clicking over the blue control surface window and selecting "Default positions" should resize the windows to match the console layout.
    If not for some reason, then you should be able to change the size of the display window to match the layout on the console the same way you resize anything in windows, by clicking+dragging a side or a corner.....the system should store the window size and maintain it everytime you launch the H3PC app.
    I don't use a tablet much, so let me know if this is different than H3PC on a "normal" machine for some reason.
    Hope this helps:)
