problem with time
Hello all
I use a hog III v2.6.0 software and when i update a cue in the cuelist the time change. The console is no tracking, the cues have different times and they have mark. I dont know if the mark is the problem...I think it takes the times of the next cue...
Any suggestions?:confused:
Thank you
  • Are you using update and forward off? I think there's some serious problems/bugs with timing...
    Check also following threads.
    forums.highend.com/showthread.php?t=6111
    forums.highend.com/showthread.php?t=5465
  • thank you Sami!
    I saw in the thread you posted that we have the exact same problems... Just hoping the bug will be dealt with soon...
    In the meanwhile, have you any suggestions/tricks you use to overcome this?
    Maybe if I merge instead of updating or something like that?
