bug 2.6
i have fill the window of cues..
when i record another cue...example 22 or 23 cue.
this dont appear..unless i close the window and open again.
same in the patch...i need to path a new fixture for see other fixtures in the row of the window:nono:
and some times...some butons in the windows are flikering..
aranajoseluis
mexico
  • There are a number of logged cases where the cuelist window doesn't properly redraw and show the correct number of rows in the cuelist window. One of these cases is when you record multiple cues to a list. Another case is when undoing the recording of a cue. Instead of closing/reopenning the cuelist window try pressing the choose button associated with that cuelist. That should be a quicker way of properly refreshing the window.
    The patch window shouldn't require patching additional new fixtures when you can't see the last fixtures in the window. I would recommend trying to toggling View by DP or closing/reopenning the patch window to get that last row to show up. We are currently investigating the cases in which the patch window decides not to draw in the last row of fixtures.
