Programing
hi,
What is better for Hog3 console.
when i programing many effects for moving lights for example .
it is better record for a cuelist and play from this or record to effect window and play it live from the window and when end press clear??is it on a cuelist more certainly?
thanks for tips
dol
  • Hi,
    i find cuelists more accurate but some people use comment macros to trigger lists and others like to play it live like yourself.
    It might also depend on the show or event in question.
    Best C
  • You can also use virtual masters. Just add release coe to the end of the list and then you can run it from the touch screen.
    Regards, sulkkis
  • Hi,
    You mean started the cuelist from cuelist directory?is it the same to virttual master?
  • Yep. You can do a lot of different things that way and have fast and easy access to them. Just make sure you will have all settings right.
    It's handy when you do not know exactly what going to happen. Of course, if you know the show and have time best way is to do a cue stack and when running the show just hit play.
    If you use programmer un the fly the fades etc will look uncontrolled and there is a risk that you will touch the trackball...
    Best regards, sulkkis
