[quote=SBlair]Like most programs, odds are it would require a special 64-bit version of the software.
I would suggest running in any type of 32-bit compatability mode if available.
Scott:
while it is possible to invoke specifically the 32-bit CLR via WOW64, strong-naming convention dictates that this option be set at compile time.
it's usually a simple matter of explicitly setting your Target Platform to x86, rather than the default of Any CPU.
so, more correctly, it requires software that claims it can run on "Any CPU" to be actually capable of doing so, free of x86 dependencies.
to expand on the previously-provided error details:
[code]System.TypeInitializationException was unhandled Message: The type initializer for 'Highend.DL2.Management.Server.MainClass' threw an exception.
'ContentManagementApplication.exe' (Managed): Loaded 'C:\Windows\assembly\GAC_64\mscorlib\2.0.0.0__b77a5c561934e089\mscorlib.dll' 'ContentManagementApplication.exe' (Managed): Loaded 'C:\Program Files (x86)\HighEnd\Content Management Application\ContentManagementApplication.exe' 'ContentManagementApplication.exe' (Managed): Loaded 'C:\Program Files (x86)\HighEnd\Content Management Application\Highend.DL2.Tools.dll' A first chance exception of type 'System.BadImageFormatException' occurred in ContentManagementApplication.exe [/code] where BadImageFormatException would confirm the rejected attempt to load 32-bit code into 64-bit space. i'd guess the native wrappers in HighendManaged.dll, as that's the only non-ILONLY assembly.
