Check to make sure that the front plate of the console is seated properly....I've seen a few cases where keys get physically stuck if the alignment is off.
It requires the old buttons to be de-soldered and the new buttons soldered in place. Applying too much heat to the PCB can cause damage to the traces and vias.
