Color Blasts and Hue and Saturation
Please forgive me if this is a stupid questions, however, I have a gig coming using a Hog IPC and many color blasts. We are also using the PDS-750-TR. I want to use the hue and saturation feature, however, it does not seem to work . I can only bring them up with intensity(which brings up everything. or I can bring up each individual RGB color. what am I missing. I feel stupid not knowing, as I am sure it is somthing simple.
I would be greatly appreciative to any thoughts on the matter
thanks:confused:
  • That is correct. You can either only bring up intensity via RGB or the master which is all 3. However, when you bring up the master intensity (which brings up everything), then you can go into hue and saturation and make the colors work.
