hi gents, i would to build a fixture with 8 channels,when i build it .at end the touchscreens freeze in grey and the console has no function.its the builder no functionality ?:dunno:
Yes, there can be probelms when using the Fixture Builder....that's why they put so many warnings up before you use it..;)
I've found that it is much more stable in H3PC for some reason....so take your file on to a laptop and build it there....then re-load.....it usually works better this way.
Hi Guys, I cannot confirm your posts that the fixture builder works better on H3PC. Most times I tried to open it, it crashed. Except, it was the first thing I did after launching the program.
