two quick questions...
...easy ones, too, probably...
How do I enable programmer timing, so that live alterations using presets uses the default parameter timing? (I'm so far gone right now, I can't even remember what it's called on the Hog II :dunce: )
how do I get the tilting top section of the expansion wing to keep the same angle as the screens on a RoadHog? I mean without having to revert to tape or pieces of string...
