(2071) Bug Report: GM with Parameter Wheel Doesn't Always Work
Date: 11/03/08
Software Version and build number: Full Boar v2.6 (2071)
Number of displays: 2 (internal only)
Connected USB Devices: Keyboard
Networked Devices: None
Detailed description of the problem including instructions to reproduce (if possible) and exact syntax used:
I have 12 layers of Catalyst v4 patched. They are patched starting at 1 on Universe 1.
GM is still loaded on Fader 1 and Fader 1 is at FL. Holding down the GM button, the GM level appears above Wheel 1. Soetimes, spinning the param wheel at this point does not result in any change in GM percentage or actual level.
However, once the GM level 'takes' and is different than the Fader 1 level, GM on param wheel consistently works.
If for example, I have control of the GM with Fader 1, I take Fader 1 (GM) to FL. If I then attempt to take control of the GM with Param Wheel 1, I can not.
If I then take Fader 1 (GM) to 95%, I can SOMETIMES take control of the GM with the Param wheel.
If I then take the GM to 50% (using the Param Wheel), I can consistently control the GM using the Param wheel...until I 'grab' the GM with Fader 1 by bringing Fader 1 to the same level.
This is the same show and console as these:
forums.highend.com/showthread.php?t=6636
forums.highend.com/showthread.php?t=6647
Let me know if you have any questions.
Phil
