Problem with install on iPC
I am having issues installing V3.0.0 (build 2417) from V2.6.0 (build 2071) The configuration panel upgrades fine but when installing Hog 3PC I get the following error "There is a problem with this windows installer package. A Script required for this install to complete could not be run. Contact your support personnel or package vendor"
XPe version is 7.9.
Any clues as to why this happening. I am installing from a 1GB memory stick and the installer package is the only file on it.
Parents
  • Hi guys,
    Here we have the same problem with our iPC will not work with new image.
    8.2.2 image works fine after downgrade.
    System:
    Hog iPC
    MB: ASUS A7N8X-VM/400
    CPU: AMD Sempron 1,66GHz
    Ramm: 512MB
    Video: ATI 9250/256MB PCI (was replaced due to crashing of console)
    Frontpanel PLD: v0
    Frontpanel FirmWare: v1.2007.6.14
    Frontpanel HardWare: v0
    Hope you have enough info.
    Otherwise just email me.
    Greetz,
    LEn
Reply
  • Hi guys,
    System:
    Hog iPC
    Ramm: 512MB
    Frontpanel PLD: v0
    Greetz,
    LEn
Children
No Data
