I want to see what fixtures that is in one group (yeah, i can open the programmer to see what fixtures that are selected), i would have the option to edit a group exactly like other pallettes (colour, position e.g.).
Hi Queerdoo. As far as I know you can't open any group editor as you do for palettes, for groups are intended to be a fast way to recall a bunch of fixtures; they don't have any information whatsoever. If groups were kind of referenced then your idea, of having a group editor would make definitely sense. Marco:hogsign:
Groups can not be opened in a similar manner to palettes. A group is just a recall of a fixture selection. You can however merge into groups and record or record/remove into groups. To recall a group you can just simply select the group and the fixtures will be selected in your programmer.
but just hitting update, after made the changes in a 'group-editor', is more sophisticated to mine opinion... and it should be possible to attach IPCB-parameters to a group,like high- and low-light
