iPC failed communication with front panel
Am into upgrading the software on the second of two iPCs. The software upgrade was done via Restore 8.3. The first upgrade went fine. But on the second iPC, I am running into a "failed to communicate with the HogiPC front panel. Hog iPC must exit" error message once it restarts.
Is this a hardware or software issue? And what do I need to do to resolve this problem?
thanks
Patrick
