1/17/09
V3.0.0 b2417
1 - Hog III
1 - X-Wing
2 - DP 2000
ESP Vision
Issue - I have a cue list that is firing other cue lists during a song. When these two lists are fired, the desktop locks up as well as the front panel (choose buttons, ICBF buttons). Playback is not affected and the main go button still works. The two lists that are being fired are both set as cue only, reset on release, release on next go. One of them is a 4 step chase, the other is an FX intensity chase. The cue stack looks like this....
Cue 1 GL3 (4 step chase)
Cue 2 GL4 (FX intensity)
Cue 3 GL3
Cue 4 GL4
repeat.....
I use this sequence a few times during the song and each time it will lock up the desktop. The desktop will eventually un-freeze and catch up to the cue, but it takes up to 45 seconds for that to happen.
Initally, I was firing the 4 step chase and intensity chase manually (go off zero, or using flash buttons) and was seeing the same thing. I initally thought that maybe the button presses were confusing the desk so I set it to fire automatically and still had the same results.
I have other cue lists that also fire other lists, but this is the only one that has this problem.
