Frozen Attribute Blocks...
Hi, I was programming on an IPC and a few times, i would look up and in the 4 boxes above the wheels that usually show the attributes, the first two boxes would show Cue Rate and Cue Effects and the 2nd two would be blank. They would freeze like this. I could select groups but couldn't use the wheels. Yhe differant attributes would not appear in the boxes. I had to restart the console to get them out. Any suggestions ?
