Hog3PC can't connect to Server or crashes
Hi everybody,
I've installed the new Hog3PC 3.0.1 b2425 on a Vista Home Premium 32b system.
Before running it the first time, I deactivated the third party firewall (windows firewall is always deactivated) and set the application to start as an Administrator.
At first the application startet with loopback network settings, so I changed them to the WiFi-adapters specifications. Trying to start a show resulted in not connecting to the server. So I tried with waiting two times. After that I changed the network-settings from using DHCP to manually configured, aplly and changing back to DHCP.
Now the application seemed to connect to the server, crashed and left all processes running. All Hog3PC processes seem to run (using CPU load) except the fpdriver-win32-golden.exe.
What can I do, to see the application or to prevent the crashing?
Regards
Andy
