For some shows now i've experinced problems with my DMX, Suddenly MH's behave erraticly, or in an instance not at all...?? Always only a couple of them....The problems seem to be dependant on whether or not I Terminate the signal at my DMX splitter... The funny thing being that the problem is there when I DO terminate the signal?!? I've tried different brands of splitters, same results.. So now I suspect the DP2000... Anyone knows of this problem??, I'm running a refresh rate of 30 hz, on the DP, have tried other rates, no difference.... Would It be possible to get a DMX timing chart for the DP2000, timing values for "Break", "Mark after Break" "Mark time between Frames and packets", general values of how the DP2000 build the DMX signal.... These values would sertainly help me diagnose if My DP2000 is sick or not....
System:
WH III running 3.0.0 software
DP2000 Running 3.0.0 software
Thanks in advance
Nicolai :hogsign:
sorry if my spelling if off ;-/
