I would like a function where the flash button can act as the go button aswell. So not only will cue 2 trigger but it wwill momentarily put the intensity of the cue to 100%. I can think of quite a few cases where I would love this. Appologies if this is already a feature, if it is, i cant find it...
You can do this already it is called (+ Go off zero) you can find it under the options for the cuelist, under the master, click action. you can also set it to (+release at zero) and then you can also change the intensity level of the click/bump to something other the 100%.
