External DVI Screen
i had this problem in V2.6.0 and it still seems to exist in V3.0.1...
If i'm using a third display with my iPC connected to the DVI-out this display will be used as the second screen. The touchscreen is still working, but when i'm pressing into the left one (normally it should be the second touchscreen), the cursor jumps into the DVI-display... I fixed this problem by using an adapter from DVI to VGA... Is there any other way to solve this problem...?
thanks in advance
Christian
