maybe bug report? v3.0.1
Console: Road Hog
Software: v3.0.1 XPe image 1.2.0
So I wrote a little audience ballyhoo cue, and it works great. No problems with the actual running of the cue. However, what's just strange is that I have the cue as an IPCB crossfader with the flash button as +Go on flash. I wrote the cue as a loop between cue 1 and 2, with the two positions being the bally positions. What I see is when I hold down the flash so that it runs the ballyhoo, I see the percentage increases by 100% each time I press the flash button. So I've pressed it 18 times, apparently, and it shows 1800% percent.... Every time I press it, though it does increase so the next time will be 1900%, the time after 2000%. When I release the button, it lets go, and all is good, but just every time I press the button the percentage increases.
So it works, and the cue does run, and doesnt have any faulty playback, but just has the weird seemingly never-ending percentage.
Let me know if I need to further explain this.
Parents Reply Children
No Data
