hog3pc 3.0.1 with wyg
since i install V3.0.1 , i can 't connect to wyg ,
i think first , it was the connectivity driver , i install the new connectivity driver, the result is the same,
when i worked with the v2.4 and wyg 22 ,there is no problem,
so i decided to uninstall V3.0.1 and reinstall the V2.4 with the connectivity driver for the V2.4 , and now it doesn't work with wyg 22
i don't understand why ?
please help me
Parents
  • I have the same problem with connectivity, however, what is strange is that I was able to connect with v3.0.0 in the Beta stages. It never connects, just hangs on the same as above when not connected.
    Here's my exact setup:
    Windows XP SP3
    WYG R22
    HogPC v3.0.1
    All on the same computer, and all firewalls/other malaise disconnected.
    I have made sure all are on the same port (6600) and that the Hog has a DP2000 now as user 2. I changed the address inside of WYG to show address 2. I also have ensured the new connectivity driver is installed. I do not get the III symbol though (which should show up with the connectivity driver), instead I get the flying pig symbol showing up, as was original with WYG.
    Maybe I'm just doing something wrong, as I have gotten the system to connect a separate time. Well, I assume that's the problem actually. Any ideas would be appreciated. Also, if I'm leaving something out that could help, let me know.
Reply
    Windows XP SP3
    WYG R22
    HogPC v3.0.1
Children
No Data
