Hi I am currently, running some Cheap LED Pars.
The channel config is as follows:
1 - Red
2 - Green
3- Blue
4 - Some random effect that is never used, so will always be at 0%
5 - Some random effect that is never used, so will always be at 0%
6 - Some random effect that is never used, so will always be at 0%
I am using the Generic >> RGB Personality for it.
This works fine for just generic looks, and simple colour changes, but I want to start adding in intensity chases. The problem here is, when I take the unit to 100% on the desk, all RGB lights come on - obviously, if I select red only the Green and Blue goes off when Red is 100%. But, I can't seen to do decent colour bumps in Effects. I have to put the unit to 100%, so if I do a Red Bump, it goes between Red and 'white', rather than red and 'black'.
I have also tried intensity chases such as Smooth and Fader to 'chase' with the red only on, however, once again the unit comes back 'white' when it does chase.
Can anyone recommend a way (either editing fixtures, or creating new ones) where I can make this work, so that I can put an LED in any colour and put an intensity effect over it?
Cheers
Neil
