Is there a way to change the default numbering of cues? For example when doing theatre shows I like to use only odd numbers on the first go around. This prevents the stage manager from having to call LX Q 33.355. Renumber the list at the end is not an option because the SM would then have to redo the whole promt script, not going to happen. It would be handy to be able to change the step size for the cue numbers. Right now each step is one whole number, I would like to increse that to two so that the order will be 1,3,5,7,9.
I saw this request and it reminded me of an idea I've been meaning to request. Maybe it could be added to this one. I like to keep my Mark cues as even decimal points. When I renumber a list, is there a way to make it ignore certain numbers? Like any .2's for example?
It is an interesting idea and of course useful. To implement might be tricky as you will have to define what values to "ignore". Plus you probably would want it to renumber the value before the decimal (so that cue 15.2 becomes 16.2 after a renumber). We will have to think on this a bit...
