I'm trying to create some per fixture beam palettes that have mostly direct information, but reference a palette for zoom/focus. Say I record a beam palette as per fixture containing focus and zoom information only for 12 m2k's (beam 2). I then goto create a new beam palette containing the remaining peremeters, then click on the zoom/focus palette I created earlier (beam 2). When I record it (to say beam 3), I click record, more, allow refs, and it records to beam 3. it shows up in the beam directoryas a referenced palette. yet when i apply it (beam 3) to the 12 fixtures, it shows as it applying the palette to zoom/focus, yet the output doesn't reflect it. Am I doing something wrong? :poke:
I think this is because your second beam palette is not per fixture as well. Try making the palette, which references the first palette, per fixture as well.
Correct. I figured it out last night after a while of playing with different options. Since I was able to get it to work once, I knew I was doing something wrong. It was only a matter of back tracking my steps. Thanks Chris!
