Is there a logged request to have an option that when a show is started the map mode (keyboard shortcuts enabled) is turned on? I almost always program and run a show in map mode, particulary when using Hog3PC. When I train people on installs they want to use the keyboard shortcuts but typically forget to press Pause/Break until they realize the shortcuts are not working.
Additionally, I often use VNC to remote into a Hog3PC setup whether it is the show sever or not. I use RealVNC as a viewer but I have yet to find a viewer that passes the Pause/Break key on to the server PC. Many of the programs use the Pause/Break key to toggle full screen mode in the viewer. This means if I start a new show via VNC I have get somebody to go to the real keyboard to press the Pause/Break key for me.
Kevin Montagne
kevin (at) litkam (dot) com
www.litkam.com
