Additional Keyboard Mappings (Enhancement #7379?)
On searching this forum I found a reference to enhancement #7379 related to providing additional keyboard mappings. Is there any update on the status of this?
The shortcuts I miss most from the Hog2PC days are the keys that would allow the parameter wheels to be adjusted by holding down the appropriate key (F9-F12 on the Hog2PC, I believe) and using the up and down keys. I often use VNC to remote into a Hog3PC setup when walking around on the stage or out in the house. It can be very difficult to manipulate the parameter wheels using the mouse in a VNC viewer. If I recall correctly in Hog2PC the Control/Pig key could be held down as well for fine control of 16-bit parameters using the up/down keys. I know F9-F12 have other meanings now but there are still keys available on the keyboard. It may be challenging to find 4 adjacent keys unless something like Shift1-4 is used.
Kevin Montagne
kevin (at) litkam (dot) com
www.litkam.com
Parents Reply Children
No Data
